Rebuilt Holley NH Straight through carbs
Topic author - Posts: 576
- First Name: Bruce
- Last Name: Compton
Four rebuilt straight through Holley NH carbs. All have pressure tested original floats, cleaned passages, restored throttle bores/shafts and new choke return springs. #1 is perfect and is $285.00. #2 has had a fuel inlet repair and is $260.00. #3 has had part of the choke snout ground off (better breathing??? ) an a repair to the fuel inlet and is $235.00. #4 has had the mounting bolt holes enlarged and is $235. None of the modifications or repairs harm the operation. All are available with a re-machined and polished original needle or a viton tipped needle (your choice).
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
- MTFCA Number: 25458
Re: Rebuilt Holley NH Straight through carbs
Hi Bruce, I will take #1 .Let me know how much with postage Ken. I will send a pm
