Restored Stromberg OF Carburetors
Topic author - Posts: 584
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
I have two restored Stromberg OF carbs, one early and one late. Both have been ultrasound cleaned, bead blasted, all jets remove and cleaned, throttle shaft/bore rebushed, new gaskets and modified original needle valves with viton tips. Both have been adjusted correctly and test driven on my car to insure proper operation. Your choice @ $550.00 plus shipping
- Last Name: Saylor
- MTFCA Number: 1695
- MTFCI Number: 23870
Re: Restored Stromberg OF Carburetors
Bruce, i am interested in the one on the right. Do you take trades. I have one that needs rebuilt. What is your exchange or rebuild price.
John
John
- First Name: Bruce
John, I can have a look at it. Hope it's totally complete as parts are almost non-existant (Stan makes some steel parts), so the only other way to get parts is buy another carb. Send me a PM. Bruce
- First Name: Tom
- Last Name: Zimmer
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1914 touring 1915 speedster
- MTFCA Number: 15920
I've never tried and OF, I've heard lots of positive comments re. performance improvement. My question, how do they do with and early t w/o a starter. Are they as easy to crank start as the NH?
They work great . I drove my original 1911 Torpedo cross country in 1984 with a OF crank start . Best carb
- Last Name: Hanlon
- MTFCA Number: 50191
Mine starts 1/4 turn warm, haven't tried cold cranking. It usually starts with two strokes choked and fires up on the third, cold with the starter.
Very noticeable improvement in power and fuel mileage.
- Last Name: Osterman
My only negative experience was due to the brass float not being smooth causing the needle control weights to work rough and on occasion getting stuck causing a dump of gas until I remove the cover and reposition the float. When it was working smoothly it was great.
- First Name: Bruce
Both Strombergs are sold. Probably the two nicest ones I've ever had. Thanks MTFCA
- First Name: Bruce
Mark : All the Stromberg OF floats have a soldered hole on one end. I'm guessing a tiny hole was intentionally punched there to avoid a pressure build up when the seam was soldered . After soldering the seam a small blob of solder sealed the "vent" hole. You will note that there is only one hole, so I always put the float in with the soldered hole at the bottom to prevent the solder from interfering with the brass weights. Repositioning the float doesn't do much as the float "floats" and will eventually rotate around the needle and cause the same problem.
- First Name: Arturo
- Last Name: Valdez
Carbs still for sale
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
- MTFCA Number: 25458
