Looking to find a pair of front fender brackets, a horn button assembly that mounts to the top of the steering column with 2 small machine
screws, a right hand front spring perch that has the centering lug on top between the spring shackle bushing and the hole for the wishbone to go through, and a right hand spindle with the round shoulder were the inside wheel bearing butts up against. Lastly a pair of windshield hinges and a drag link with the ends that are riveted on.
Any help with any of the above parts will be greatly appreciated.
Wanted for 1915
Topic author - Posts: 433
- First Name: Philip
- Last Name: Lawrence
- MTFCA Number: 5591
- MTFCI Number: 25062
- Board Member Since: 2014
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Wanted for 1915
I likely have most, if not all of the parts you're searching for - I'll inventory today & get back to you.
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
Re: Wanted for 1915
I have the horn button and most likely the front brackets, Bob
815-633-7244
815-633-7244
Re: Wanted for 1915
Thanks Steve and Bob PM's were sent to you both.
Re: Wanted for 1915
I'll send you photos tomorrow, Philip.
Re: Wanted for 1915
Thanks Steve, look forward to receiving them.
