Rebuilt ECCO carburetor for Model T
Topic author - Posts: 584
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Excellent rare ECCO brass carb and manifold. It's been used, but looks like NOS inside. Perfect original float, zero wear in the throttle shaft, no wear on the mixture screw tip, and the original needle/seat seals tight. The was one crack in the brass bowl that was repaired at some time along with a few minor dings , but it does not leak. The only adjustment is the mixture control (from the dash). This carb looks very similar is size and design to a U&J. Asking $550.00 plus shipping for the set-up.
