Looking for driveshaft spool
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Post by Michael Paul » Wed Aug 14, 2019 8:13 pm
Hi, I'm looking for a closed driveshaft spool for 1911. I'm not sure what style was used, I understand there are subtle differences between the early and later. Anyone have a photo of the one I need? Or better yet have one I could buy?
Thanks Mike
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Re: Looking for driveshaft spool
Post by Michael Paul » Thu Aug 15, 2019 1:55 pm
Still looking, can anyone tell me what the difference is between the early and late closed spool?
rgould1910
Last Name: Gould
Post by rgould1910 » Thu Aug 15, 2019 4:04 pm
Couple things. The earliest has the round rear flange without the bumps for the bolt holes and the number T191 embossed in the body. It accepts 3/8" studs. All I have seen have been redrilled at the factory(?) to accept 13/32" studs. The following spool has the round flange as above but has the number T 191 B embossed in the body. That's the the one you want for a 1911 car. They are not that hard to find, but you may have to pay a fair amount for one. The last closed spool has bumps in the rear flange area where the bolts pass thru. That one is by far the most common. The first two are illustrated below.
rgould1910
Last Name: Gould
Post by rgould1910 » Thu Aug 15, 2019 4:09 pm
on
Post by TRDxB2 » Thu Aug 15, 2019 5:05 pm
There are several T191B for sale on EBAY all about $30 & $15 shipping.
rgould1910
Last Name: Gould
Post by rgould1910 » Thu Aug 15, 2019 5:20 pm
Just a head's up. The ones I see on eBay have the bumps on the rear flange where the bolts pass thru. The one Michael needs is the one with the full round flange. Agree all will do the job, but if you are concerned about having the right part for the year, the 191 B pictured above is the right one.
rgould1910
Last Name: Gould
Post by rgould1910 » Thu Aug 15, 2019 5:22 pm
rgould1910
Last Name: Gould
Sorry for the double post.
Post by TRDxB2 » Thu Aug 15, 2019 8:29 pm
Is this a correct T191B or another variation. I don't see the bumps on the ones on your pictures
https://www.ebay.com/itm/FORD-MODEL-T-E ... SwwGNdLa-y
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Post by Michael Paul » Thu Aug 15, 2019 10:01 pm
Thank you for the great info, I know what to look for now. I rather have the correct one, my chassis was all correct other having a later drive shaft.
Mike
rgould1910
Last Name: Gould
Post by rgould1910 » Fri Aug 16, 2019 9:40 am
Frank, the one pictured above is the later style used after 1912 until the open spool was adopted. They are the most common type seen and go for about $40 around here.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Mon Aug 19, 2019 2:36 pm
I have a nice one, just what you are looking for. Complete with sleeve and bearing, though I can't vouch for the bearing's condition. $125 plus postage. A lot, I know, but it is very nice.
Post by Wayne Sheldon » Wed Aug 28, 2019 4:40 am
For whatever it is worth? Layden Butler just posted one for sale.
viewtopic.php?f=5&t=6292
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Wed Aug 28, 2019 2:42 pm
Mine has been spoken for. Thanks for all the inquiries.
