FS Black Era Headlight Bucket
Posted: Mon Aug 12, 2019 6:32 am
by d stroud
FS. This bucket is a black era bucket and has the "flat" sides where it fits into the fender brace/headlight mount. I don't recall the years, it is earlier than the ones with the tapered sides. It isn't one of the early ones with the focus screw on top. It is useable, but not perfect by any means. It has some paint on the upper half, both inside and out. There are four very minor dents in it, very easy fix and has the bulb socket and adjusting screw intact, probably still has the unobtainium screws for the wires. BUT, the bottom 25% of the bucket has some rust from water setting in it. There is one very small crack at the slot for the ring, and a bit of a rust swell in the inside between the top and bottom bracket rivets. The bottom is pretty thin around the slot for the ring, but the ring would still hold the lense. There are some marks from a pipe wrench from when someone "adjusted" the headlights.Threads for the nut will clean up very nicely. Some lettering on the back around the plug, can't quite make it out, looks like, TJC LAMP CO CIN OHIO. Would be good for a survivor, doodlebug, or driver. $10.00 plus shipping, I can text pictures. Dave
..XXXXXXXXXXXXX
Re: FS Black Era Headlight Bucket
Posted: Wed Aug 14, 2019 2:18 am
by d stroud
Bump. Dave
Posted: Fri Aug 16, 2019 2:56 pm
by d stroud
Bump. Dave
Posted: Mon Aug 19, 2019 4:38 am
by d stroud
How about $7.50 plus shipping? Dave
Posted: Thu Aug 22, 2019 12:26 am
by d stroud
Bump. Dave
Posted: Mon Aug 26, 2019 2:50 am
by d stroud
Bump. Dave
Posted: Wed Sep 04, 2019 5:04 am
by d stroud
Found another bucket, not quite a match, but has the same "flat" sides where it mounts on the fender brace. Overall condition is quite a bit better, no dents, minor surface rust on the outside and on the lower third on the inside, has the nut (threads will need to be chased as well as the threads on the stem), stem is very nice, bulb socket is there, but may or may not be useable. This will clean up very nicely with a bit of work. $15.00 for the pair plus shipping, I can text pictures. Dave
Posted: Wed Sep 04, 2019 10:41 pm
by d stroud
Mike, PM sent. Dave
Posted: Fri Sep 06, 2019 2:53 am
by d stroud
Bump. Dave
Posted: Mon Sep 09, 2019 7:34 am
by d stroud
No reply from Mike, so back up for sale. Dave.
Posted: Thu Sep 12, 2019 5:30 am
by d stroud
Bump. Dave
Posted: Mon Sep 16, 2019 4:19 pm
by d stroud
Bump. Dave
Posted: Thu Sep 19, 2019 5:06 am
by d stroud
Bump. These buckets aren't perfect, but very useable with a bit of work. Dave
Posted: Sun Sep 22, 2019 3:58 am
by d stroud
Bump. Dave
Posted: Tue Sep 24, 2019 5:16 am
by d stroud
$12.50 for the pair plus shipping. Dave
Posted: Wed Sep 25, 2019 8:50 am
by mvweaver
Dave, I'll take them. Sending you a PM. - Matt
Posted: Thu Sep 26, 2019 12:16 am
by d stroud
Thanks Matt. PM sent. Dave
Posted: Fri Sep 27, 2019 12:54 am
by d stroud
Matt, another PM sent. Dave
