WARFORD GEAR BOXES
Post parts for sale here
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
WARFORD GEAR BOXES
Post by Chaffins » Mon Aug 12, 2019 3:54 pm
Have 2 Cast Iron Warford Gear Boxes, no cracks or damage, $100.00 ea plus shipping
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Re: WARFORD GEAR BOXES
Post by Chaffins » Thu Aug 15, 2019 12:03 pm
bump
1925TT
First Name: Forest
Last Name: Ledbetter
Board Member Since: 2014
Post by 1925TT » Thu Aug 15, 2019 12:13 pm
Just the cases, or do they have the gears?
23lmnt
Last Name: Nielsen
MTFCA Number: 49701
Post by 23lmnt » Thu Aug 15, 2019 12:55 pm
I have a complete cast iron Warford gearbox, gears look good, shifts fine and has the adapter on the front for the other U-Joint.
I'd like to sell it, $300 plus freight
Mark
kenhaverhill
First Name: Kenneth
Last Name: LeBlanc
Post by kenhaverhill » Thu Aug 15, 2019 7:48 pm
Mark what do you think it would cost to ship to 01832? I also have a Fastenal a few towns over also thanks ken
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Fri Aug 16, 2019 1:17 pm
UPS to 01832 would be $41.75
kenhaverhill
First Name: Kenneth
Last Name: LeBlanc
Post by kenhaverhill » Fri Aug 16, 2019 8:12 pm
Sounds good mark send me an address for the check thanks Ken
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Fri Aug 16, 2019 8:26 pm
KEN 1939N S. MAIN ST CORONA CA 92882 $141.75 GLEN (MARKS DAD)
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Fri Aug 16, 2019 10:54 pm
1939 S. MAIN ST. NO N
kenhaverhill
First Name: Kenneth
Last Name: LeBlanc
Post by kenhaverhill » Sat Aug 17, 2019 8:35 am
I was interested in the complete unit for $300 that mark was selling ,maybe a mix up ?
tmodeldriver
Last Name: Hester
MTFCA Number: 26459
MTFCI Number: 20813
Post by tmodeldriver » Sat Aug 17, 2019 10:48 am
Feller probably shouldn't jump into the middle of one guy's ad and start selling his own stuff. Just saying...
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Sat Aug 17, 2019 12:06 pm
$300.00 IS A GOOD PRICE IF THEY HAVE GEARS. I SOLD 2 GOOD ONES FOR $450.00. BUT IF THE GEARS ARE NOT GOOD FORGET IT. GLEN
Post by Scott_Conger » Sat Aug 17, 2019 5:43 pm
Bob Hester is absolutely right!
BAD FORM TO ADVERTISE ON SOMEONE ELSE'S F/S AD !!!!! Any way I can make myself clearer??? :?:
This is Chaffin's ad...no one else's
Model T Tom
First Name: Thomas
Last Name: Butterworth
Post by Model T Tom » Sat Aug 17, 2019 6:22 pm
Mark not good of you to jump on someone's ad .
kenhaverhill
First Name: Kenneth
Last Name: LeBlanc
Post by kenhaverhill » Sat Aug 17, 2019 6:30 pm
Sorry for the confusion Glen,when I saw mark I assumed it was your son where as it was on the same add. Ken
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Sun Aug 18, 2019 2:03 am
OK I think there is still room for confusion. No one has been able to tell me if you can put the gears from a aluminum case warford into a cast iron case to bolt it direct to the back of the T trans like the aluminum case . If this is possibility I would be interested especially if some one would pick it up & bring it to the San Diego speedster run for a $20 dollar bill (just trying to save a bit )
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Aug 18, 2019 11:14 am
Some gears with fit depending on year of manufacture but the majority will not. The idler shaft down low is larger on the cast iron (truck) models, the gears are in some are of different tooth count, and etc.
Hope this Helps,
Hank in Tin-A-See
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Mon Aug 19, 2019 1:23 am
Thanks Hank,
