26/27 motor block and re-babbitted mainbearings
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Late series casting type motor block and caps … 14million,173 thousand number range (14,173,XXX) , mainbearings were re-babbitted and oil grooves cut in a demonstration for our local Northern Colorado Model T club years (Centennial T years ago)… mains are linebored to STANDARD DIAMETER … the mains are ready to go IF you have a good STANDARD DIAMETER or new SCAT crankshaft to install … cylinder bores are +.020 … cylinders should be bored and valve seats ground … there is a weld in the back of block between a head bolt and outside water passage … deck has been re-surfaced , but may need additional re-surfacing ...price is $250 + freight … this is way less than the price of re-babbitting and linebore … always an optimist Gene French phone 970-581-2808
- First Name: Gene
- Last Name: French
Re: 26/27 motor block and re-babbitted mainbearings
Gentlemen:
will have this block and my linebore units and bearing molds at the AACA swapmeet on Sept 21/22 … this is the 51 st. annual meet and has a mix of early and later parts … there will be several model T and model A parts vendors including myself … always an optimist ...gene French 970-581-2808
- First Name: Gene
- Last Name: French
Gentlemen:
the block is spoken for … thanks MTFCA
