I have enough parts to assemble several complete chassis: Wishbones, axles, perches, springs, spindles, tie rods all in near perfect condition. I have three good frames, rust free rear axle parts, lots of suspension, engine, and transmission stuff and boxes of miscellaneous.
If you are interested and a snowbird coming to Florida bring a pickup or trailer. The more you buy the better the deal!!
Wishbones, Axles, Perchs, Springes, Spindles, Tie Rods in Near Perfect Condition
Topic author - Posts: 362
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
- MTFCA Number: 50484
- MTFCI Number: 24737
Re: Wishbones, Axles, Perchs, Springes, Spindles, Tie Rods in Near Perfect Condition
Please reply to richsclassiccars@bellsouth.net or 561-262-0393.
- First Name: Rich
I have a new tapered front spring, I don't believe it is original Ford.
I also have enough miscellaneous leaves to build several springs (see pictures).
- First Name: Rich
Picture of used original exhaust pipe and new tapered aftermarket spring.
- First Name: Tyler
- Last Name: Ray
- * REQUIRED* Type and Year of Model Ts owned: 1916 runabout
- MTFCA Number: 50192
Rich, I am restoring a 1916 runabout, and I’m in need of a good set of correct front spring perches and a good wishbone. Please let me know what you have available. Thanks!
Tyler
Tyler
- Last Name: Seress
- MTFCA Number: 27707
Rich, I need a rear axle truss. That thick wire that spans from one side to the other under the axle and strapped on both sides to keep the axle from sagging. Frank
