Thanks to the forum i have located a front universal joint just looking for help locating a rear collar... I understand it looks like in the image below...
Thanks Stuart 914 217-340 [img][/img]two
WTB - Muncie Transmission Rear Collar
Topic author - Posts: 14
- First Name: STUART
- Last Name: McDIARMID
- Attachments
- muncie rear http://www.mtfca.com/discus/messages/118802/154976.jpg
- Muncie Collar 154976.jpg (8.15 KiB) Viewed 240 times
- First Name: Layden
- Last Name: Butler
Re: WTB - Muncie Transmission Rear Collar
These couplings are straight thru and of proper size. Just cut off to length, best done with an abrasive blade.
Fantastic - where did you find the item Layden ? I assume you cut the lug ends off ...
- Last Name: Butler
On eBay:
https://www.ebay.com/itm/NEW-Spicer-10- ... SwLVFbl88z
Yes cut the leg end off. Maybe someone can measure theirs for you, mine are not accessible.
Thanks Layden - you have saved me days of searching - taken your advice and already purchased... hopefully it will be installed by the weekend
