Moore overdrive transmission F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Tue Apr 16, 2019 8:34 pm
Marked OD for overdrive on the case, not one of the much more common underdrive ratios, made for TT truck but readily adapted to car use. 2 speed unit direct- full neutral and over drive. $650, will have at Auburn CA Swap Meet in June if not sold or can store and deliver there.
Re: Moore overdrive transmission F/S
Post by Allan » Tue Apr 16, 2019 11:04 pm
Layden, there's something a bit weird going on there. It looks good at first, but then the hookup for the shifter linkage is the wrong way round. The hole should be at the front. Perhaps that needs investigating to avoid any potential problems with the purchase. It is easily fixed, but the reason for it to be fitted this way eludes me.
The under drive Moore I have in my roadster is awesome. I get a higher rear ratio by running a 3:1 crownwheel and pinion set.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Tue May 14, 2019 1:14 pm
This transmission seems to have been reassembled with the shift rod sticking out the wrong way!
Brazed places seem to have been done to seal the case as they put in oversized bolts to hold it together. Actually a well done job.
Very good condition gears. Yes it is an overdrive.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon Jun 03, 2019 11:11 am
$575 packaging included, domestic shipping at UPS rate.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon Jun 10, 2019 1:56 pm
This is a good unit!
$500
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Mon Jun 10, 2019 5:13 pm
layden, Do you know what the over drive ratio Is?
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Tue Jun 11, 2019 6:40 pm
Here is the tooth count.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Wed Jul 24, 2019 3:19 pm
ttt
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon Sep 02, 2019 3:31 pm
$450 packaging included, shipping at UPS rate.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Thu Sep 12, 2019 12:16 am
Sold
Thanks to MTFCA
