Re: Bosch front plate distributor Sold going to Ireland
Topic author - Posts: 4957
- MTFCA Number: 52564
Bosch front plate distributor. Gears and adapter were new when I put them on. Bosch 009 distributor. The bell crank holder was broke off a long time ago and was welded back on. The pin or bell crank is worn, works but might want to replace. Has the under water pipe link. The distributor is a bit loose in the hole but seems to stay centered. I would suggest a better coil, points and condenser. I have a 6 volt condenser mounted on the coil. The coil throws a blue spark but it's kinda on the weak side. $325 plus shipping, should fit in large flat rate box. Check or money order, no pay-pal on this one.
Mark
Mark
1920 Dodge touring
1920 Dodge touring
Re: Bosch front plate distributor $325 plus the ride
Oh I have a copy of the install instructions that I will include.
More photos;
More photos;
1920 Dodge touring
1920 Dodge touring
btt
1920 Dodge touring
1920 Dodge touring
$325 plus shipping. Guessing less then 2000 miles on the new gears/parts(guess on mileage, the longest tour being around 120 miles round trip rest being shorter and approx number of tours it's been on).
1920 Dodge touring
1920 Dodge touring
Friday bump
1920 Dodge touring
1920 Dodge touring
Re: Re: Bosch front plate distributor $325 plus the ride
Bump
1920 Dodge touring
1920 Dodge touring
- First Name: Nicholas
- Last Name: Bailey
- * REQUIRED* Type and Year of Model Ts owned: Family owned since 1959
Dear Sir
I would be interested in buying you front plate ignition for a speedster I am presently working on. Two questions , are you happy to ship to Ireland and will you take $300 plus shipping costs . I have bought a few Items from this section in the past but I also know some people do not like to ship over seas .If you are happy to ship can you let me know the cost and if you are happy with paypal.
regards Nicholas Bailey
Re: Re: Bosch front plate distributor Sold going to Ireland
Sold, thank you
1920 Dodge touring
1920 Dodge touring
