2 3/4 to 1 PINION GEAR
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Thu Oct 03, 2019 4:56 pm
ONLY one I've ever seen. Used but in excellent condition. Your guess is as good as mine what it needs to fit up to but if nothing else this would be good conversation at the next meeting.
$150 includes US shipping.
I prefer Paypal. Or email stanhowemt@aol.com phone 406 949 3448
Re: 2 3/4 to 1 PINION GEAR
Post by Wayne Sheldon » Fri Oct 04, 2019 5:41 am
Nice! A good friend many years ago had a set of 13/36 (original Ruckstell) gears in the Ruckstell in his speedster. It was said they were 2 3/4 to 1, but I never did the math on it. I have seen a few 36 tooth Ruckstell ring gears over the years, and very few of the special pinions for them. Because the set was made for speed, not reliability under heavy loads, the smaller ring gear requires a set-back for the pinion, hence the toothless shoulder and slight hollow on the ends. I have also read about, but never seen myself, 35 tooth ring gears. I am not sure which one this one is for. Frankly don't feel like doing the math right now.
It would be a wonderful setup for a fast speedster if one could get the ring gear to match this!
Chad_Marcheese
First Name: Chad
Last Name: Marcheese
* REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Doodlebug / 1924 Speedster Gow Job
MTFCA Number: 26904
Post by Chad_Marcheese » Fri Oct 04, 2019 5:54 am
Needs a 36 tooth ring gear to make it a 2.76 ratio.
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Fri Oct 04, 2019 7:02 am
I have three ruckstel rings and have never counted them, knew by the offset gear, I will check now!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Oct 04, 2019 7:38 am
They were used also in 3/4 midget sprint cars with 12” tires. Have one in the barn.
Hank
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri Oct 04, 2019 9:41 am
You put that gear ratio behind a Rajo....
And there’s your 100mph+ Model T speedster :D
Add 1.5 miles to get the dern thing stopped !! :shock: :lol:
Mike Howell
Last Name: Howell
* REQUIRED* Type and Year of Model Ts owned: 23 Speedster, 26 Roadster
MTFCA Number: 28354
Post by Mike Howell » Fri Oct 04, 2019 11:50 am
I just talked to Stan and told him I'll take it. These things are hard to find! Joe, Hank, or anyone, if you find the correct ring gear to fit a Ruckstell-Please give me a call. Seven75-752-017six. Or you can pm me through this site. Thanks Stan!
"I refuse to join any organization that would have someone like me as a member." Mark Twain
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Fri Oct 04, 2019 5:34 pm
All three are 39
Mike Howell
Last Name: Howell
MTFCA Number: 28354
Post by Mike Howell » Fri Oct 04, 2019 9:49 pm
Thanks for checking, Joe.
Dennis Fleming
Last Name: Fleming
* REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
MTFCA Number: 27815
MTFCI Number: 19314
Post by Dennis Fleming » Sat Oct 05, 2019 10:46 am
I have a 44 tooth NOS ring gear. What would that fit on ?same bolt pattern as standard T ring gear
Dennis Fleming
Last Name: Fleming
MTFCA Number: 27815
MTFCI Number: 19314
Post by Dennis Fleming » Sat Oct 05, 2019 10:48 am
Mike I sold a 23/4 ring gear several years ago to the guys at McPherson Collage . They may still have it.
Mike Howell
Last Name: Howell
MTFCA Number: 28354
Post by Mike Howell » Sun Oct 06, 2019 9:56 am
Dennis: I'll send you a PM for any contact information you might have. Thanks, Mike.
