re-babbitted ball caps ( 4th.main )
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat May 16, 2020 7:22 pm
Rebabbitted Model T ball caps ( 4th. main) … this is an updated advertisement … due to difficulty in purchasing quantities of ball cap cores I will be requiring that a buyer send a core … the price of ball cap will remain the same ($45.00 plus $15.50 postage in lower 48 states ) … this is a change from old ad's in that I will need a CORE … regarding cores … use some judgement … if you don't want to get that part back ...DON"T send it as a core … while you probably will not get the core you send in … someone will … I will re-Babbitt in groups of 20 pieces to keep my process efficient and cost low … I am able to supply in standard diameter or in undersizes … I cam machine diameters down to 1.500" to fit clutch plates that have been machined for ball bearing ball caps … I typically stock Standard , -.002" , -.005" diameters … please accurately measure the tail shaft and provide that dimension to assure correct fit ...
always an optimist ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
First Name: Gene
Last Name: French
Re: re-babbitted ball caps ( 4th.main )
Post by Gene_French » Sun May 17, 2020 9:52 am
Gentlemen:
should have added my address for the core shipment … Gene French 49519 cr.23 Nunn,Co. 80648
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jun 14, 2020 9:20 am
to the top again , thanks MTFCA
william
First Name: William
Last Name: Rathert
Post by william » Sun Jun 14, 2020 4:13 pm
Mine came back yesterday, fit like a glove! Super job! Thank you Gene.
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Aug 22, 2020 8:15 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Mon Sep 28, 2020 4:43 pm
to the top again ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Oct 02, 2020 9:58 am
