Brand New / Modern 6 Volt Model T Starter
Don_Larson
First Name: Don
Last Name: Larson
Post by Don_Larson » Thu Nov 07, 2019 8:38 am
Another Great Day Friends!
What I found in the bowels of my garage - a Brand NEW 6-Volt Model T Starter - A Modern Starter manufactured to Specs to exactly fit the Model T -
Never used - Still in the box. It is a modern Starter and does not 'exactly' match the 'look' of the original Starter - But 'functionally', is better than the original -
Asking $250. NO CORE Required - But you will have to pay for Postage - (Weight total is #20 pounds including Box). If you need new Bendix Springs, Gear, Nuts, Washers and Bolts, Key, etc. for a 'complete' starter 'Bendix Unit' - I'm sure I have anough NEW parts to include - for another $50. bucks!
Feel Free to ask any questions or, if you need more photos, info -
Have a Great week - "Pa" Larson
DLWrldwide@aol.com / 407-492-9364
Shaft and 'Keyway' exact specs for Model T -
'Imprint' on the Casing
Complete Starter
Complete Starter
Starter and Original Box - Imprinted "Model T - 6-Volt
Afrazer
First Name: David
Last Name: Frazer
Re: Brand New / Modern 6 Volt Model T Starter
Post by Afrazer » Fri Nov 08, 2019 10:42 am
Does it wire up like an original? I’m interested in it if it does and can call you for more details when I am off work
1925 closed cab TT
1925 factory roadster pickup
1926 two door sedan
Don_Larson
First Name: Don
Last Name: Larson
Post by Don_Larson » Fri Nov 08, 2019 5:19 pm
Starter has been Sold - Thank You
