Columbo, Apollo front plate magneto drive
Posted: Fri Nov 08, 2019 12:58 pm
A beautiful Columbo brand magneto cross drive, magneto mounting plate. These were also sold under the Apollo brand. High quality, Identical. These have spring loaded cam gears for very easy set up. Both ends of the magneto coupling is there. Excellent unit on a running engine. These are sought after because of the built in extended oil filler cap, and they just look so snazzy and are bulletproof. Your Ford mag quit and you want to run again? This is a lot cheaper than pulling an engine. Any type of magneto will work, and I have deals on those, too. ASK. Best one I’ve had in a long time, as they usually have issues. Please look elsewhere if you want issues or excuses. $500 + postage tmorsher@icloud.com is the only way to reach me, no PMs, don’t ask me to call or write, no smoke signals, telegraph messages, or mental telepathy, just one-finger type like I do , send an email on your computer thingy to tmorsher@icloud.com I’m a pretty simple guy. Thanks!
