Rebuilt U&J carbs/manifolds
Topic author - Posts: 576
- First Name: Bruce
- Last Name: Compton
I have four rebuilt U&J carbs and three aluminum intakes. I'll start with this one that is the only one I've ever seen with six small idle mix holes instead of the regular single larger hole. This carb has a polished original needle, repaired throttle shaft, new choke spring, an enriching plunger, a new float, and a Holley G steel bowl. Main jet is pre-set at 3/4 turns out and may need fine tuning for your engine. Asking $750.00 with the manifold or $650.00 without plus shipping.
- First Name: Bruce
Re: Rebuilt U&J carbs/manifolds
New price : $650.00 with the manifold or $600.00 without the manifold plus shipping (maybe $35.00) I can ship from Florida after Dec 20th.
