Mainbearing linebore Model T and A Ford
Topic author - Posts: 376
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $875 plus $75 priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Mainbearing linebore Model T and A Ford
I just got mine from Mr French last week. WOW, Absolutely beautiful Workmanship, can’t wait to use it coming this summer.
Thank You Gene!
Hank in Tin-A-See
Thank You Gene!
Hank in Tin-A-See
- First Name: Gene
- Last Name: French
Henry:
thank you , if you have any questions call or email … also , will get the carbide bits off to you probably toward the end of next week … will be having a cold spell and I will work in the shop instead of on the house … also will try to post a larger size photo with this note … always an optimist...gene french
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Hi Gene,
You always making awesome tools.
It will be nice having a short video how that tool work just for my knowledge and also for other folks.
Cheers,
Mario
Cheers,
Mario
Super Mario Bross
1911 Touring
1914 race car project
1911 Touring
- First Name: Gene
- Last Name: French
Gentlemen:
I can deliver to Chickasha swapmeet March 15-16 at no charge … I will be at space SL4 in the south building … always an optimist...gene French 970-581-2808
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- Last Name: Williams
Gene,
Do you or know anyone that sells a line boring set up for 1926 chevy?
Mark
Mark
Gene might be able to help. The mains are the same type as the 28, insert. Filling Station offers the service for reporing the mains.
https://www.fillingstation.com/shop/?ye ... rchtype=FT
You could also ask over at;
https://vccachat.org/
If you have not see this over on HAMB, it could be a good read on hot roding a 28 Chevrolet engine. Some of the information might work on a 1926 engine too. There are I think 73 pages and I have only read part of it.
https://www.jalopyjournal.com/forum/thr ... or.463465/
There is some info on mains in it.
1920 Dodge touring
1920 Dodge touring
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
- First Name: Gene
- Last Name: French
to the top again , thanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
to the top again ... thanks MTFCA
- First Name: Gene
- Last Name: French
to the top again , yhanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
