Mainbearing linebore Model T and A Ford
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sun Jan 27, 2019 6:02 pm
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $875 plus $75 priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Mainbearing linebore Model T and A Ford
Post by Henry K. Lee » Sun Jan 27, 2019 6:07 pm
I just got mine from Mr French last week. WOW, Absolutely beautiful Workmanship, can’t wait to use it coming this summer.
Thank You Gene!
Hank in Tin-A-See
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 27, 2019 11:08 pm
Henry:
thank you , if you have any questions call or email … also , will get the carbide bits off to you probably toward the end of next week … will be having a cold spell and I will work in the shop instead of on the house … also will try to post a larger size photo with this note … always an optimist...gene french
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Jan 30, 2019 10:26 am
Hi Gene,
You always making awesome tools.
It will be nice having a short video how that tool work just for my knowledge and also for other folks.
Cheers,
Mario
Super Mario Bross ;)
1911 Touring
1914 race car project
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Feb 02, 2019 9:24 am
Gentlemen:
I can deliver to Chickasha swapmeet March 15-16 at no charge … I will be at space SL4 in the south building … always an optimist...gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Feb 19, 2019 9:41 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Mar 09, 2019 10:46 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Apr 04, 2019 10:28 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 03, 2019 9:36 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue May 28, 2019 10:14 pm
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Jul 02, 2019 8:36 pm
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Aug 08, 2019 3:25 pm
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Oct 11, 2019 11:56 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Wed Oct 30, 2019 11:02 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Dec 01, 2019 11:18 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 12, 2020 9:51 am
top
ModelTMark
Last Name: Williams
Post by ModelTMark » Sun Jan 12, 2020 10:37 pm
Gene,
Do you or know anyone that sells a line boring set up for 1926 chevy?
Mark
Post by Mark Gregush » Mon Jan 13, 2020 12:32 am
Gene might be able to help. The mains are the same type as the 28, insert. Filling Station offers the service for reporing the mains.
https://www.fillingstation.com/shop/?ye ... rchtype=FT
You could also ask over at;
https://vccachat.org/
If you have not see this over on HAMB, it could be a good read on hot roding a 28 Chevrolet engine. Some of the information might work on a 1926 engine too. There are I think 73 pages and I have only read part of it.
https://www.jalopyjournal.com/forum/thr ... or.463465/
There is some info on mains in it.
1921 Huckster
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Feb 07, 2020 9:18 am
to the top again ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Mar 21, 2020 9:54 am
to the top again , thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Apr 14, 2020 7:39 pm
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 08, 2020 9:00 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jun 14, 2020 9:15 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Jul 16, 2020 10:00 am
