Mainbearing linebore Model T and A Ford
Posted: Sun Jan 27, 2019 6:02 pm
by Gene_French
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $875 plus $75 priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
- linebore1.jpg (2.88 KiB) Viewed 11212 times
Re: Mainbearing linebore Model T and A Ford
Posted: Sun Jan 27, 2019 6:07 pm
by Henry K. Lee
I just got mine from Mr French last week. WOW, Absolutely beautiful Workmanship, can’t wait to use it coming this summer.
Thank You Gene!
Hank in Tin-A-See
Posted: Sun Jan 27, 2019 11:08 pm
by Gene_French
Henry:
thank you , if you have any questions call or email … also , will get the carbide bits off to you probably toward the end of next week … will be having a cold spell and I will work in the shop instead of on the house … also will try to post a larger size photo with this note … always an optimist...gene french
Posted: Wed Jan 30, 2019 10:26 am
by Quickm007
Hi Gene,
You always making awesome tools.
It will be nice having a short video how that tool work just for my knowledge and also for other folks.
Cheers,
Mario
Posted: Sat Feb 02, 2019 9:24 am
by Gene_French
Gentlemen:
I can deliver to Chickasha swapmeet March 15-16 at no charge … I will be at space SL4 in the south building … always an optimist...gene French 970-581-2808
Posted: Tue Feb 19, 2019 9:41 am
by Gene_French
top
Posted: Sat Mar 09, 2019 10:46 am
by Gene_French
top
Posted: Thu Apr 04, 2019 10:28 am
by Gene_French
top
Posted: Fri May 03, 2019 9:36 am
by Gene_French
top
Posted: Tue May 28, 2019 10:14 pm
by Gene_French
top
Posted: Tue Jul 02, 2019 8:36 pm
by Gene_French
top
Posted: Thu Aug 08, 2019 3:25 pm
by Gene_French
top
Posted: Fri Oct 11, 2019 11:56 am
by Gene_French
top
Posted: Wed Oct 30, 2019 11:02 am
by Gene_French
top
Posted: Sun Dec 01, 2019 11:18 am
by Gene_French
top
Posted: Sun Jan 12, 2020 9:51 am
by Gene_French
top
Posted: Sun Jan 12, 2020 10:37 pm
by ModelTMark
Gene,
Do you or know anyone that sells a line boring set up for 1926 chevy?
Mark
Posted: Mon Jan 13, 2020 12:32 am
Gene might be able to help. The mains are the same type as the 28, insert. Filling Station offers the service for reporing the mains.
https://www.fillingstation.com/shop/?ye ... rchtype=FT
You could also ask over at;
https://vccachat.org/
If you have not see this over on HAMB, it could be a good read on hot roding a 28 Chevrolet engine. Some of the information might work on a 1926 engine too. There are I think 73 pages and I have only read part of it.
https://www.jalopyjournal.com/forum/thr ... or.463465/
There is some info on mains in it.
Posted: Fri Feb 07, 2020 9:18 am
by Gene_French
to the top again ...thanks MTFCA
Posted: Sat Mar 21, 2020 9:54 am
by Gene_French
to the top again , thanks MTFCA
Posted: Tue Apr 14, 2020 7:39 pm
by Gene_French
Posted: Fri May 08, 2020 9:00 am
by Gene_French
Posted: Sun Jun 14, 2020 9:15 am
by Gene_French
Posted: Thu Jul 16, 2020 10:00 am
by Gene_French
Posted: Sat Aug 22, 2020 8:12 am
by Gene_French
Posted: Fri Oct 02, 2020 9:54 am
by Gene_French
Posted: Sun Oct 25, 2020 10:47 am
by Gene_French
Posted: Tue Dec 01, 2020 8:58 am
by Gene_French
to the top again ... thanks MTFCA
Posted: Sat Dec 12, 2020 8:44 am
by Gene_French
to the top again , yhanks MTFCA
Posted: Sat Jan 02, 2021 9:32 am
by Gene_French
Posted: Tue Jan 12, 2021 11:15 am
by Gene_French
Posted: Fri Apr 09, 2021 10:55 am
by Gene_French
Posted: Sat Apr 24, 2021 8:46 am
by Gene_French
Posted: Sat May 08, 2021 8:58 am
by Gene_French
