11 tooth pinion
JIvers
Last Name: iversen
* REQUIRED* Type and Year of Model Ts owned: '16 C cab PU, '22 speedster, '23 touring, '25 PU.
MTFCA Number: 16548
11 tooth pinion
Post by JIvers » Tue Nov 12, 2019 8:01 pm
Here's the second gear of the two mentioned in my 10 tooth ad. $120 shipped USA
Haroldc30
First Name: Harold
Last Name: Chambers
* REQUIRED* Type and Year of Model Ts owned: 1925 fordor. 1923 touring
MTFCA Number: 50278
Re: 11 tooth pinion
Post by Haroldc30 » Tue Nov 12, 2019 10:15 pm
Is this still available?
JIvers
Last Name: iversen
MTFCA Number: 16548
Re: 11 tooth pinion
Post by JIvers » Tue Nov 12, 2019 10:48 pm
Harold, It is--which is surprising--at the prices I'm seeing for these things. I'm just so used to losing money in every hobby in which I engage that I'm now incapable of thinking in terms of extracting the top dollar for anything. And, after all, consider all the fun I had tearing down all those rear ends to get a very few non-trashed parts! Consider--this gear has a pitted look in and around the key way but rust was not evident when I removed it. Seems to have been a result of the casting. If that is of concern to you--poor photographer that I am--I'd try to provide detail of it.
