Oil can holder for your modern auto
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Nov 14, 2019 9:34 pm
Just in case you have a modern car in your stable, such as Henry’s Lady, we are now offering an accessory oil can holder that easily mounts on the model A firewall. Simply remove one gas tank nut and bolt, and use the same nut and bolt to securely install the bracket. The early model A’s came standard with an oil can. Until now, you’d take chance on having one under the seat and spill, or to be misplaced in the shop somewhere. The model A needs her lubrication, too. Made similar to the model T style, and perhaps you don’t want to drill any holes in your T firewall? This one can be , with your ingenuity , attached along the T hood shelves. Same terms, $45 postpaid to your door. Tmorsher@icloud.com to reach us, the only way! Great stocking stuffer
Dropacent
Last Name: Morsher
X-mas stocking stuffer Oil can holder for your modern auto
Post by Dropacent » Wed Dec 04, 2019 9:35 pm
Holiday bump, great stocking stuffer for the Model A lover you might know. Tmorsher@icloud.com
