Ford 11 Tooth Pinion Gear
Posted: Mon Dec 02, 2019 11:43 pm
by tselliott
This gear is attached to a shortened drive shaft that has the pinion bearing with it. The pinion bearing cage is a little loose, but the rollers look good. The gear has no chipped teeth but has some minor pitting on a couple of teeth. Overall very usable gear.
$60 plus shipping
Scott Elliott
971-5O6-94O2
