WTB Prest-O-Lite Acetylene brackets 3''
Topic author - Posts: 1198
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
I would like to buy brackets for my prest-o-lite exactly like on the picture. I bought a set but unfortunately to large 6''. I need 3" Brackets. If someone have 2 straps of 3" of diameter it will be awesome. Please send me pictures.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Re: WTB Prest-O-Lite Acetylene brackets 3''
Mario
The MC tank does not use the same type of latching brackets. The were a bolt on bracket that generally mounted to handlebars.
For what it is worth, the MC tank will work fine for a static display and short demonstration of acetylene headlamp operation, however for long term continuous use, you will need a type E or B tank.
Keith
Keith
- First Name: Mario
thank you Keith for the info, really appreciated. Did you have perhaps pictures of bolt on bracket that generally mounted to handlebars?
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Keith
Mario-
Here you go!
The 3" tank, designated as a MC tank, was designed for use on MotorCycles.
Sometimes those brackets were used to hold a handle and used as a plumber's torch:
I designed and built this acetylene MC tank set up mounted under the back seat floorboards of my 1911 years ago.
It worked fine, but I wanted to use the headlamps continuously and safely, so I got a B tank and brackets then designed this adapter so the Prest-O-Lite brackets mount to the running board using the holes that mount the E&J carbide generator. I did not want to drill any hole in my original running boards. Because of the shape, I called this adapter an E-dapter:
Here is my E-dapter sitting on the running board with the E&J generator bracket sitting on top of it to show the relative attachment location:
I still have the MC tank under-the-floorboards-assembly. Let me know if you are interested in it.
-Keith
Here you go!
-Keith
- First Name: Mario
Awesome Keith. I will custom by my own the brackets... I saw on ebay how much they asked for a pair, it's $300. Way Too much. I will invest on my handcraft abilities..
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Keith
I look forward to seeing some pictures!
- First Name: Matt
- Last Name: G
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
- MTFCA Number: 30697
Anyone know what this went to?
Matt
Matt
- First Name: Layden
- Last Name: Butler
Catalog says "quick detachable tire tank band".
A compressed air tank went in this to carry compressed air to inflate tires.
