WTB Prest-O-Lite Acetylene brackets 3''
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Tue Dec 10, 2019 2:21 pm
I would like to buy brackets for my prest-o-lite exactly like on the picture. I bought a set but unfortunately to large 6''. I need 3" Brackets. If someone have 2 straps of 3" of diameter it will be awesome. Please send me pictures.
prestolite 2.jpg (50.11 KiB) Viewed 3132 times
Super Mario Bross ;)
1911 Touring
1914 Speedster
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Re: WTB Prest-O-Lite Acetylene brackets 3''
Post by KWTownsend » Wed Dec 11, 2019 12:30 am
Mario
The MC tank does not use the same type of latching brackets. The were a bolt on bracket that generally mounted to handlebars.
For what it is worth, the MC tank will work fine for a static display and short demonstration of acetylene headlamp operation, however for long term continuous use, you will need a type E or B tank.
Keith
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Dec 11, 2019 9:26 am
thank you Keith for the info, really appreciated. Did you have perhaps pictures of bolt on bracket that generally mounted to handlebars?
1911 Touring
1914 Speedster
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Wed Dec 11, 2019 10:58 am
Mario-
Here you go!
The 3" tank, designated as a MC tank, was designed for use on MotorCycles.
Acetylene MC tank 1913-reading-standard-4.jpg (38.99 KiB) Viewed 3043 times
Sometimes those brackets were used to hold a handle and used as a plumber's torch:
prestolite plumbers torch.jpg (35.14 KiB) Viewed 3043 times
I designed and built this acetylene MC tank set up mounted under the back seat floorboards of my 1911 years ago.
It worked fine, but I wanted to use the headlamps continuously and safely, so I got a B tank and brackets then designed this adapter so the Prest-O-Lite brackets mount to the running board using the holes that mount the E&J carbide generator. I did not want to drill any hole in my original running boards. Because of the shape, I called this adapter an E-dapter:
Here is my E-dapter sitting on the running board with the E&J generator bracket sitting on top of it to show the relative attachment location:
I still have the MC tank under-the-floorboards-assembly. Let me know if you are interested in it.
-Keith
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Dec 11, 2019 11:14 am
Awesome Keith. I will custom by my own the brackets... I saw on ebay how much they asked for a pair, it's $300. Way Too much. I will invest on my handcraft abilities..
1911 Touring
1914 Speedster
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Wed Dec 11, 2019 3:45 pm
I look forward to seeing some pictures!
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
MTFCA Number: 30697
Post by Matt in California » Sat Dec 14, 2019 11:50 am
Anyone know what this went to?
Matt
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Dec 14, 2019 12:48 pm
Catalog says "quick detachable tire tank band".
A compressed air tank went in this to carry compressed air to inflate tires.
