Wanted
cchigaridas
First Name: Chris
Last Name: Chigaridas
MTFCA Number: 0
Wanted
Post by cchigaridas » Fri Dec 13, 2019 2:30 pm
I need a good 1915 left rear axle housing. 805-557-1768
MTFCA Number: 14972
MTFCI Number: 15411
Re: Wanted
Post by RajoRacer » Fri Dec 13, 2019 4:35 pm
Driver's or Passenger side ? And what state do you reside ?
Philip Lawrence
First Name: Philip
Last Name: Lawrence
MTFCA Number: 5591
MTFCI Number: 25062
Board Member Since: 2014
Re: Wanted
Post by Philip Lawrence » Fri Dec 13, 2019 10:29 pm
Left would be drivers side (No oil filler hole). 1915 would also have no reinforcements ribs on outside flanges ( opposite of wheel, facing center of rear end ).
Burlingtontguy
Last Name: Michaud
Board Member Since: 2010
Re: Wanted
Post by Burlingtontguy » Sat Dec 14, 2019 8:20 pm
I have a pair Sandblasted ,clean, and painted, $250 plus shipping
Re: Wanted
Post by Allan » Sat Dec 14, 2019 11:31 pm
Left is the correct description. Passenger or drivers side is confusing when one considers there are LHD and RHD cars. The left side is correct regardless, unless you are one of the
" view from the front" crew who believe a LHD car then becomes RHD.
havnfun
First Name: Joe
Last Name: Kowalczyk
MTFCA Number: 49558
MTFCI Number: 24878
Re: Wanted
Post by havnfun » Sat Dec 14, 2019 11:39 pm
in the US the side is determined from sitting behind the steering wheel, facing forward, drivers side is the left side...
Regards,
Joe Kowalczyk - 1923 Touring, 1913 Speedster, 1913 Runabout
Email: havnfun@cableone.net
(208) 870-3099
Re: Wanted
Post by Allan » Sun Dec 15, 2019 12:21 am
Joe, that's the point. The left side is the left side when facing forward, regardless of where the driver sits, regardless of the country of origin.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Wanted
Post by D Stroud » Sun Dec 15, 2019 3:04 am
Allan is correct. Left or right side is determined from where you are setting in the driver's (operator's) seat, no matter which side of the road you are driving on and no matter what you are driving or operating. Dave
1925 mostly original coupe.
