For Sale: Rebuilt Hall Scott Rear Axle Assembly
Topic author - Posts: 147
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1910,1911,1912,1913.1914
- MTFCA Number: 27737
For sale is a rebuilt Hall Scott 2 speed rear axle assembly mated with a 1915 rear axle housing. Included are rebuilt drive shaft and radius rods and your choice of shifter levers. One is the the original shifter that bolts to the driveshaft and is in the center of the floor boards or one that is on the left side next to the brake lever,made from a Model T brake lever and cross member. Ready to bolt in. $1,950.00 Picked up or I can deliver to Chickasha at no charge if paid in full. I will email more photos on request. email to : johnlhaynes(at)hotmail.com or call 308 207 557zero.
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Re: For Sale: Rebuilt Hall Scott Rear Axle Assembly
Hi John, sent a text to your phone. Mike
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Is this an overdrive or a underdrive?
- Last Name: Haynes
Hello Chris,
This is an underdrive. It is an early Ruckstell. Hall Scott sold out to Ruckstell. Let me know if you have any more questions.
- Last Name: Haynes
The Hall Scott Axle has been sold. Thank you MTFCA and Thank you John! Merry Christmas!
