Maintenance Free Timer
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Sat Dec 21, 2019 5:20 pm
The Ideal Timer is now available for use with properly adjusted Model T coils that provides the best Model T engine performance possible using stock coils and Never needs Maintenance!
The Ideal Timer (I-Timer) is a direct, drop in, replacement for the stock Model T timer that provides precise coil activation and never needs maintenance. Start on battery and Run on Magneto or battery as usual. The I-Timer is immune to timing cover misalignment and provides precise coil activation without wiper bounce, contact skip, contact wear, arcing or other mechanical flaws. The I-Timer does not require periodic maintenance, lubrication or replacement. Simply replace your mechanical timer with the I-Timer and enjoy smooth, optimal engine performance at any engine speed with properly adjusted Model T coils. Imagine; Never clean, lubricate or replace your timer ever again! Click the link to order the I-Timer http://shop.modeltetimer.com/I-Timer-Th ... -Timer.htm
I-Timer Features:
• Direct mechanical timer replacement
• Uses the original car wiring without any changes
• Uses properly adjusted Model T coils
• Operates on battery OR Magneto
• Maintenance free operation
• Never wears out
• The Ideal Timer!
For best performance, we recommend coils be adjusted for equal and consistent firing Time using the ECCT coil tester: www.modeltecct.com
MKossor
Last Name: Kossor
MTFCI Number: 22706
Re: Maintenance Free Timer
Post by MKossor » Thu Jan 09, 2020 7:30 am
Precise coil activation
No messy maintenance
Win / Win
