Wanted original valve grinding tool
Topic author - Posts: 336
- First Name: Charles
- Last Name: Jenkins
- * REQUIRED* Type and Year of Model Ts owned: Coupe
- MTFCA Number: 28066
Looking to buy a tool that fits in the two holes in the stock Model T valves to real lap or grind the valves Charlie 937 408-2480 thanks stay warm -4 here
Re: Wanted original valve grinding tool
To actually do the work, a NeWay cutter set is far more accurate. https://www.cylinderheadsupply.com/newa ... tters.html. If you call NeWay, they will help you put together the exact kit of tools to do the job...they know our cars and their products and will sell you only what you need. They are very nice and helpful.
If you're just collecting tools, well, that's another story.
NH Full Flow Float Valves
I know this I would like to own one of the tools
- Last Name: Hanlon
- MTFCA Number: 50191
I have one Charles, I will look when this weather breaks. I will add it to the list
- Last Name: Hanlon
Which Springfield are you in ?
- MTFCA Number: 14972
- MTFCI Number: 15411
If Dave can't supply, I have one also.
I understand there's several different styles I'm interested in any that is for sale I have a showcase with Model T parts and accessories would love to have some for it
Still looking any help would be appreciated
- Last Name: Hanlon
I'll let you know tomorrow...
Supposed to be a tropical 42 degrees !!
- First Name: Harold
- Last Name: Schwendeman
Charles J. - I purchased a nice set of valve seat cutter equipment from Neway quite a few years ago, and have only done "valve jobs" with that equipment ever since. However, for what it's worth, I used to have one of the old hand crank devices that I bought as a kid in the '50's or '60's that was always used back then to hand "lap" valves. As I remember, it would oscilate (sp?) back and forth a partial turn while turning the valve a bit further with each turn. What I also remember, and what might be of interest to you Charles, is that I remember that the "working end" of the shaft of that hand-cranked grinder had a slot in it, and a hole for a pin that would lock several different devices to the grinder for grinding different sizes/types of valves. One of those "devices" was a rubber suction cup, and there were also a couple different sized flat key type devices with two little "nubbins" that would fit in valves that had the two holes in them. The "nubbins" (my word) were spaced differently in the different flat key type attachments to accommodate different types of valves that had different "spacing" of the two holes in the valve heads.
All of the above from memory Charles, as I have no idea what ever happened to that "antiquated" old valve grinder that I'm pretty sure I probably bought from Warshawsky's (J.C.Whitney predecessor) in Chicago when I was a kid.
For what it's worth,.....harold
- Last Name: Hanlon
Charles, I believe that I have one like Scott showed, but it did not reveal itself.
I did find this one however...send me an email if you're interested.
A Marvel brand
A Marvel brand
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Valve gringer have couple if them an email if you still need
Jalopyt@yahoo.com
Jalopyt@yahoo.com
Ok guys I still don't have one yet looking for the one that will work on stock model T valves mattatsunrise@aol.com 937-408-2480
Well I can say with certainty that your request is a total mystery. You asked for a tool that fit the two holes in a T valve. You've been shown and offered tools that do just that.
You do realize that original valves had holes and modern valves, do not, right?
If you know that and have rejected all tools that fit the holes, then perhaps this is what you want:
https://www.modeltford.com/item/3052T.aspx
Unless you get specific, I suspect folks will grow tired of guessing. At least I am.
I have not rejected anything I'm willing to purchase one or a couple just need somebody to send me a price and where to send the money Thanks
The one that Dave looks fantasticwilling to purchase it just need to know a price and where Dave wants me to send the money to Thanks
Here's several I have hanging on one of my "T" tool boards - I'd part with 1 or 2.
The one that has the horse shoe look and the other one that has the big door knob look or both extremely cool
I've made several attempts to contact both through here and the email address you sent me - I sent you another photo.
Steve I don't understand all the rest of my emails are coming through mattatsunrise@aol.com Tex 937-408-2480 hope we can get together
- Last Name: Hanlon
Email works for me...
