PRODUCTION ASSETS SALE
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Thu Feb 20, 2020 12:32 pm
BUSINESS OPPORTUNITY. AFTER 47 YEARS WE ARE COLSING OUR DOORS. OUR PRODUCTION OF RUCKSTELL AND OTHER PARTS FOR THE MODEL T FORD IS COMING TO AN END. OUR PRODUCTION ASSETS ARE EXTENSIVE. OUR SALE INCLUDES ALL PATTERNS, CORES, PRODUCTION TOOLING WITH ALL DRAWINGS AND PRODUCTION INFORMATION AND SOURCES. IT INCLUDES ONE SAMPLE OF EACH PART THAT WE MANUFACTURE. WE MANUFACTURE ABOUT 300 DIFFERENT PARTS INCLUDING THE RUCKSTELL AXLE AND PARTS, RUCKSTELL 40 TOOTH RING GEAR, 12 TOOTH AND OTHER PINION GEARS, HIGH VOLUME INTAKE MANIFOLD, DUAL EXHAUST MANIFOLD, NEW CAMSHAFTS, FORD FAITHFUL OILER, WIND WINGS, EARLY AND LATE SPRING SHACKLES, CLUTCH SPRING, ROD BOLTS, REAR AXLE INNER OIL SEALS, BOSCH FRONT PLATE DISTRIBUTOR, BOSCH FRONT PLATE CONVERSION KIT, HEAT TREATED REAR AXLE SLEEVES, REAR AXLE SHIMS, STEWART SPEEDOMETER DRIVE SETS, BRAKE DRUM SHOES, BRASS ROBE RAIL, EARLY CRANK HANDLES, CRANK SHAFT PULLEYS, EARLY BRASS FAN PULLEY, CARBURETOR CONTROL RODS, WOOD COIL BOXES, WINDSHIELD HINGE PIN BOLT AND SPRING SETS, WINDSHIELD GLASS CAPS AND COUNTLESS SMALL NUTS , BOLTS AND OTHER SMALL PARTS FOR THE MODEL T FORD.
THE ASSETS WILL BE OFFERED IN TWO CATAGORIES AT COST: OUR PATTERNS, CORES AND TOOLING COULD NOT BE REPRODUCED TODAY AT THESE COSTS
1. RUCKSTELL ASSETS ONLY: $100,000.00
2. ALL ASSETS $150,000.00
FIRSTV COME, FIRST SERVE
GLEN CHAFFIN, CHAFFIN'S GARAGE INC. 951-735-4791
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Re: PRODUCTION ASSETS SALE
Post by Chaffins » Sun Feb 23, 2020 1:51 pm
XXXXXXXXXXXXXXX
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Mon Feb 24, 2020 12:09 pm
XXXXXXXXXXXXXX
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Tue Feb 25, 2020 11:13 pm
XXXXXXXXXX
Chaffins
First Name: Herbert
Last Name: Chaffin
MTFCA Number: 227
Post by Chaffins » Sun Mar 01, 2020 3:37 pm
XXXXXXXXXXXXXX
