Spacer for Model A crankshaft in T block F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Wed Jan 08, 2020 7:22 pm
Aluminum spacer used when installing a Model A crankshaft in a Model T Ford block. $25, domestic postage $8.
Matt_A_1926
First Name: Matt
Last Name: Atchinson
Re: Spacer for Model A crankshaft in T block F/S
Post by Matt_A_1926 » Fri Jan 10, 2020 6:51 pm
Layden, is this the spacer you use to set the higs head back and also you'll have to move the front a bit as well?
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Thu Jan 16, 2020 5:42 pm
Hogs head stays where it is. The block moves forward on the pan.
