1923 scat crank short block for sale DEEP DISCOUNT !!! Now $4500.00 or best offer!
David Mazza
First Name: David
Last Name: Mazza
* REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Post by David Mazza » Thu Jan 16, 2020 7:33 pm
NOW $4500.00 with free delivery within 150 miles of 01247( north Adams Massachusetts)
I have finally decided to sell my completely rebuilt 1923 model t short block. The block was done at J and M machine in Southborough Massachusetts. The block was baked clean as well as the head and oil pan. The block and head were then blasted clean to clean iron. The block and head were both magnafluxed and any cracks found were repaired with lock and stitch and then pressure tested. The oil pan was placed on krw pan jig and it’s dimensions corrected and also new hand crank bushing installed.
All new parts were used in the build of the block. Features are as follows
- Scat standard splash oil crank. This crank was fine balanced before assembly by J and M. So accurate the balance, the belt pulls was installed and a small index mark made to return it to balance after assembly.
- new babbit poured by J and M and also align bored.
- stipe motor cams .250 grind cam installed in new bearings.
- all new three wrench style push rods installed with all three wrenches included for future adjustments
- all new stainless valves installed with hardened seats installed.
- 60 over high compression pistons.
- rods and pistons weight matched and balanced rod bearings poured and bored at J and M.
- rods drilled and oil dippers installed.
- high head milled just enough to be true and flat
- pan has Texas t parts high volume Oiler installed and the remaining parts are included to complete installation. The inspection pan retaining ring has been adjusted to fit larger scat crank. This was done with out pan gasket to ensure ample clearance. Inspection pan has been installed and sealed. New oil drain plug also installed.
- complete gasket set included
- new set of high head cylinder head bolts, new oil pan bolts and also generator mounting bolts included with various other fasteners included.
- new mag post included.
Here are several pictures, I have 54 pictures total for serious inquiries.
I am in the north west corner of Massachusetts.
The asking price for all included in the pics and description is NOW $4500.00!!!!!!
I can be contacted through pm on here or also email at
Akdavem@hotmail.com
David Mazza
First Name: David
Last Name: Mazza
Re: 1923 scat crank short block for sale
Post by David Mazza » Thu Jan 16, 2020 7:34 pm
Pics
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Jan 16, 2020 7:35 pm
More pics
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Jan 16, 2020 7:37 pm
More pics
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Jan 16, 2020 7:38 pm
Any more I can send via email. I do also have pics from J and M take while in their shop.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Thu Jan 16, 2020 8:22 pm
"any cracks found were repaired with lock and stitch and" - which means there were block cracks ? Water jacket ?
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Jan 16, 2020 9:00 pm
There were a couple insignificant cracks found in the deck and those were repaired. There was also a crack in the pan rail that most people would not even have bothered repairing but repaired it was. There were not any detrimental cracks especially no cracks in the water jackets. A side note, nearly every t block if magnafluxed will present cracks.
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sat Jan 18, 2020 8:55 am
This is something I am open to offers on! I am a reasonable man! I am not interested in trades but don’t be afraid to negotiate.
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sun Jan 19, 2020 9:05 pm
Bump.
Also I would deliver this for free within a 50 mile radius of my location. I would need help lifting it out of my vehicle upon arrival but this is something I would like to offer to help someone. Shipping something like this is something I haven’t done but could deliver it to a business of a friend for freight shipping.
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Jan 23, 2020 10:27 am
Bump up to top
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Jan 23, 2020 12:04 pm
David you have a good deal going there, cost a lot to build one on todays dollar. Good luck.
noelchico
First Name: Noel
Last Name: Chicoine
MTFCA Number: 25420
MTFCI Number: 22686
Post by noelchico » Thu Jan 23, 2020 1:29 pm
Would the high compression pistons interfere with an overhead valve head such as a Rajo C-35. Interested!
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Jan 23, 2020 2:00 pm
Noel I sent you a email.
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sat Jan 25, 2020 7:46 am
Still available
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sun Jan 26, 2020 7:41 pm
Another bump.
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Tue Jan 28, 2020 7:59 am
If you haven’t thought about what to spend your tax refunds on. Look no further!
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Jan 30, 2020 7:28 am
Bump up to top
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Fri Jan 31, 2020 2:33 pm
My private messages are not sending any interest please email directly. I do not want anyone to think I’m ignoring them! The best contact email is akdavem@hotmail.com
Also I’m am willing to deliver for free to 150 miles radius of 01247. Don’t be afraid to negotiate!
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sun Feb 02, 2020 7:37 am
Bump for Sunday!
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Tue Feb 04, 2020 3:47 pm
I am receptive to offers. I do still think the private message function here doesn’t always work for me so please use Akdavem@hotmail.com
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Feb 06, 2020 3:33 am
Bump up to top
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Fri Feb 07, 2020 2:17 pm
Bumpity bump
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sun Feb 09, 2020 7:27 am
Buuuummmpp
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Tue Feb 11, 2020 3:43 am
Up to the top
David Mazza
First Name: David
Last Name: Mazza
Re: 1923 scat crank short block for sale REDUCED PRICE!!!!!!
Post by David Mazza » Tue Feb 11, 2020 3:54 pm
Bump up to top
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Feb 13, 2020 3:56 am
Bump bump bump
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sat Feb 15, 2020 4:15 pm
Take up to top
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Mon Feb 17, 2020 8:01 am
Deep discount!!!
$4500.00 still including free delivery within 150 miles of 01247!
Akdavem@hotmail.com
David Mazza
First Name: David
Last Name: Mazza
Re: 1923 scat crank short block for sale DEEP DISCOUNT !!! Now $4500.00 or best offer!
Post by David Mazza » Fri Feb 21, 2020 6:54 am
Bump best offer still willing to deliver within 150 miles of 01247!
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Sun Feb 23, 2020 3:11 pm
Still looking for a new home
At very least there is over $3000.00 in just parts here!
Akdavem@hotmail.com
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Tue Feb 25, 2020 4:05 pm
Best offer?
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Thu Feb 27, 2020 7:25 am
Sold pending
