Valves
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
dacapt1948
First Name: Phil
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1926 tudor
Valves
Post by dacapt1948 » Sat Jul 04, 2020 1:10 pm
Hi there, I installed new stainless valves and adjustable lifters in my 1926 T. I just put the valve and lifters in and adjusted the valves to .014. Engine starts fine but engine lacks power. Should I have taken head off and re-time valves?
Thank you
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Re: Valves
Post by Joe Bell » Sat Jul 04, 2020 5:03 pm
Did you lap in the valve seats? I recut the seats then lap them in for a good seal. Hope this helps.
Last Name: Gregush
MTFCA Number: 52564
Re: Valves
Post by Mark Gregush » Sat Jul 04, 2020 9:52 pm
"If you need help logging in, or have question about how something works, use the Support forum located here"
You need to ask your question on the main forum, this is not car support.
1920 Dodge touring
