its how the camera is held
Posted: Thu Aug 26, 2021 3:42 pm
I've tried over and over--this is what i found to be my problem in posting pictures, some would come right up while others taken with the same camera would not--i was thinking if the picture is taken with the same camera how could this be,---DAH----when taking a bunch of pictures some horizontal, things fill the screen fine while others the camera needs to be held in the vertical position, that-'s where the size changes, move the object in a way so the camera is held in the horizontal position,or at times in the delete column there is a place to rotate your photograph to make it the proper size, --geeese i'm getting to be almost 1/2 as smart as this rig--i think. you need to be plugged into just pictures when rotating the photo,
