Photos
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
Duckwing
First Name: Jim
Last Name: Wilson
Photos
Post by Duckwing » Fri Sep 03, 2021 3:56 pm
Photos I post have verbiage below the photo. Also, they are not the format that shows a border around the photo. What am I doing wrong? I’m posting photos from my iPhone photo library.
Last Name: Gregush
MTFCA Number: 52564
Re: Photos
Post by Mark Gregush » Thu Sep 09, 2021 10:10 pm
Post one here so we can see what you are asking about.
1920 Dodge touring
Duckwing
First Name: Jim
Last Name: Wilson
Re: Photos
Post by Duckwing » Fri Sep 10, 2021 12:08 pm
Well, I cant post it but if you look in this thread and scroll down to my photos (Duckwing poster) you will see what I'm referring to. I guess the verbiage shows up when others view my post.
"how do you make a side mount spare tire bracket"
Last Name: Gregush
MTFCA Number: 52564
Re: Photos
Post by Mark Gregush » Sat Sep 11, 2021 9:43 pm
Ok don't know. Guess as long as you can post photos I would not worry about it. Could be where you are pulling the photos from, desk top or tablet. ?
1920 Dodge touring
Duckwing
First Name: Jim
Last Name: Wilson
Re: Photos
Post by Duckwing » Sun Sep 12, 2021 1:57 pm
Did do you view the message I referenced and did you see the verbiage on the photos?
Last Name: Gregush
MTFCA Number: 52564
Re: Photos
Post by Mark Gregush » Tue Sep 14, 2021 3:38 pm
Yes I did. If think it is some sort of back door to your computer, send a note to Jeff or Chris, their contact is listed in several places, and ask them. Tell them where you are posting your photos from, desk, tablet etc, maybe there is a work around, or it is just there causing no issues, except, the ones it is on can not be clicked and enlarged, but I have seen others that don't have the verbiage that can't be either.
1920 Dodge touring
Duckwing
First Name: Jim
Last Name: Wilson
Re: Photos
Post by Duckwing » Tue Sep 14, 2021 3:55 pm
Thanks for the input.
Last Name: Gregush
MTFCA Number: 52564
Re: Photos
Post by Mark Gregush » Tue Sep 21, 2021 12:17 pm
You are not the only one;
viewtopic.php?f=5&t=21247
1920 Dodge touring
John Goble
Last Name: Goble
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster, 1926 Speedster, 1926 TT
Re: Photos
Post by John Goble » Tue Sep 21, 2021 3:11 pm
I have never been able to post pics , anywhere else I just click on photos, my photo page opens I select a pic and say ok, but on here I click on the photo tab and some image information junk no pic.
zaborro
First Name: United
Last Name: Bronx
Re: Photos
Post by zaborro » Fri Mar 04, 2022 3:01 am
I guess you just need to upload your photos on the third-party hosting and insert here through the panel in the message. Or submit to the Gallery, perhaps.
First Name: Adrian
Last Name: Whiteman
* REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Re: Photos
Post by A Whiteman » Wed Mar 09, 2022 1:09 am
The issue is that you are adding the photos as an 'Attachment' you are missing 1 extra step in the process:
This explanation sort of sounds a bit silly but try these steps in this order:
1. Click on Attachments just below the input window,
2. Click "add files"
3. Select photos and upload
THEN
4. SELECT "Place Inline"
This will put the photo in your post at the place you selected (watch where the cursor is).
5. SELECT "Preview" to check it is OK, edit if not, then
6. Select "Submit" when you are good to go.
