Question/concern re high counts?
Posted: Tue Aug 06, 2019 7:41 pm
				The new format has been running for over six months now, and while I am bothered a bit by the reduced activity here, it has been fairly stable, with common daily high counts around a hundred on-line. The record high sat at (if I recall correctly) about 130 for awhile, then in June (if I recall correctly jumped to 196. Other than a couple VERY busy days, it was usually around a hundred at the busiest time of the day. Suddenly, we have had several high counts, over two hundred, then nearly three hundred now with a "record" high of 329! Who ARE these people? Are they legitimate model T people? Or should we be concerned we may get targeted by trolls? The registered users count has not jumped in a similar fashion. And in spite of a higher than I would expect number of registered users, the number "using this forum" is still usually between twenty and forty. Who ARE the other nearly three hundred people?
Just me. Being curious. And maybe a bit concerned. Maybe paranoid?
