Let’s try this new forum
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Re: Let’s try this new forum
Success, and a great pic to boot Tom. Love the Mag horn, never seen one mounted there before...was this common?
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Topic author - Posts: 2824
- First Name: Tom
- Last Name: Rootlieb
- MTFCA Number: 440
This forum is so much easier to use and load pics than the previous one. And the fact you can touch the pics to go full screen makes use so simple. Good job guys.
- MTFCA Number: 16175
- MTFCI Number: 14758
The horn is a retrofit, as the car came from the factory with a bulb horn. It would be up to the owner to decide where to put it. Outside the hood is a good location for it, because it's not much louder than a bulb horn.
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
From here, that looks like a motor driven Klaxon type horn. JMHO Dave
1925 mostly original coupe.
- First Name: David
- Last Name: Stroud
Steve, look at the size of the bell on that horn. If it is a Klaxon type horn, I bet it could be heard just fine! Dave
- MTFCA Number: 1219
That's a great looking '14 with seat covers. Wisconsin 1915 according to licence plate.
Glad you made it on board.
- MTFCA Number: 121
- MTFCI Number: 16310
I don't like this new forum at all! The old one was way easier to use, but then I'm old, and that's probably the problem!
I feel your pain Larry. I resist new things as long as possible. There was something familiar and comfortable the old forum had.
This forum was easy enough to get on and if it lasts longer, works better and makes it easier for those who maintain it it's a good thing.
In time it will seem as nice as the old one I am sure.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
- MTFCA Number: 2406
- MTFCI Number: 22213
C'mon Larry , most of us are old.
One thing that I do like------- Just click on the photo of the 1914 touring ,---it will show up big so I can see it.
Otherwise, I do miss the old forum.
1922 Coupe , 1926 Touring
