I had to make several for myself, so while I was set up, I made 1 spare throttle shaft. If you need one, and your carb has a .032" thick throttle plate, this is what you want. Additionally, it comes with the correct screws, so no need to reuse the boogered up old ones.
HINT: if the throttle plate is the SAME thickness as the choke plate, you have the .032" version, and this is the shaft you want...if your throttle plate is a LOT THICKER (.063) then you do NOT want this shaft.
Picture shows 2, but only 1 is for sale.
EMAIL if interested.
Thank you.
No Longer For Sale - One (1) Stromberg OF Throttle shaft for .032" thick throttle plate
Topic author - Posts: 6428
Last edited by Scott_Conger on Sat Jun 27, 2020 10:36 pm, edited 2 times in total.
NH Full Flow Float Valves
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Re: For Sale - One (1) Stromberg OF Throttle shaft for .032" thick throttle plate
Unsolicited testimonial: I've got one of these, and Scott's workmanship is gorgeous.
Thanks Chris
I'll bump this once or twice and then it'll be gone. If you're rebuilding a Stromberg OF and not replacing this part, you're not really rebuilding it. As a suggestion, if you think you'll need this in the future, you might want to act. Demand is understandably low, and I will not tool up to make one as a request...only as part of a production run and for now, this is it.
thanks, everyone, for looking.
OK
last time
say buh-buy
back on the shelf and add this to the "no one wants one" list...not that I'm at all surprised. I'll use it soon enough and will be greatful I don't have to set up to make it.
thanks for looking
last time
say buh-buy
thanks for looking
