Ideal Timer (I-Timer) Discounts for ECCT Owners
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Fri Feb 08, 2019 5:21 pm
Special Offer for ECCT Owners
You may have heard the Ideal Timer is now available for use with ECCT adjusted coils that provides the best Model T engine performance possible with stock coils. This is a special limited time offer being made to existing ECCT owners interested in purchasing an Ideal Timer.
The Ideal Timer (I-Timer) is a direct replacement for the stock Model T timer that provides precise coil activation and never needs maintenance. Start on battery and run on Magneto or battery as usual. The I-Timer is immune to timing cover misalignment and provides precise coil activation without wiper bounce, contact skip, contact wear, arcing or other mechanical flaws. The I-Timer does not require periodic maintenance or replacement. Simply replace your mechanical timer with the I-Timer and enjoy smooth, optimal engine performance at any engine speed with ECCT adjusted Model T coils. Imagine never having to remember to clean, lubricate or replace your timer ever again! For more information about the I-Timer, please visit www.modeltitimer.com
I-Timer Features:
• Direct mechanical timer replacement
• Uses the original car wiring without any changes
• Uses properly adjusted Model T coils
• Operates on battery OR Magneto
• Maintenance free operation
• Never wears out
• The Ideal Timer!
If you purchased an ECCT; Save $50 off the I-Timer: $349.95
If you purchased the ECCT + PC Software: Save $75 off the I-Timer: $324.95
If you purchased the ECCT + Magneto Test Option: Save $75 off the I-Timer $324.95
If you purchased the ECCT + Magneto Test Option + PC Software: Save $100 off the I-Timer: $299.95
This special offer ends 3/1/2019
Please include copy of ECCT equipment purchase receipt to qualify for discount. Please add $10 Shipping to lower 48 US states. International buyers, please email for shipping rates.
Check or money order only made payable to :
Mictel LLC
244N 17th Street
Kenilworth, NJ 07033
Installation and operation instructions can be viewed or downloaded from the website: www.modeltitimer. com. Questions, please email: Mictel@comcast.net
Don't own an ECCT?
Learn how to adjust your own coils for equal and consistent firing Time like a Pro using the Electronically Cranked Coil Tester (ECCT) by visiting the website: www.modeltecct.com several informative videos available there too.
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
MTFCA Number: 32518
Re: Ideal Timer (I-Timer) Discounts for ECCT Owners
Post by Tom Hicks » Fri Feb 08, 2019 6:01 pm
I have two I-Timers, they don't need lubrication, cleaning, adjusting, or maintenance. They work great! Thanks Mr. Kosser !
SurfCityGene
First Name: Gene
Last Name: Carrothers
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Tue Feb 12, 2019 3:09 pm
If these I Timers perform just half as good as the E Timer that I already have this is a must have for any long distance absolute trouble free and maintenance free driving possible!!
Thanks You so Much for making this great products to improve our Model T driving experiences!!!
1912 Torpedo Roadster
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Wed Feb 13, 2019 10:19 pm
Thanks for sharing your experience with the I-Timer.
Forgot to mention this I-Timer discount is Limited to 1 per ECCT owner and cannot be combined with any other offer. Offer ends 3/1/2019
havnfun
First Name: Joe
Last Name: Kowalczyk
MTFCA Number: 49558
Post by havnfun » Thu Feb 14, 2019 7:31 pm
I purchased the I-Timer last summer as a package deal with the ECCT, the Advanced software and Magneto testing option. Simply put, I Love the ECCT and now I also love the I-Timer. Took till fall to get the I-Timer installed, as I was really busy with other projects. Once I timed all my coils with the ECCT and installed the I-Timer, all I can say is WoW, my Speedster never ran so good. My coils where originally purchased rebuilt, car ran great, once I reset them using the ECCT, the car ran noticeably better, and when I finally installed the I-Timer, the performance improvement was very obvious. I would recommend the ECCT and I-Timer to anyone without question, fantastic products.
Special thanks to Mike Kossor for his support, help and guidance during my learning curve on rebuilding coils and learning the ECCT with it's advanced software. I now rebuild coils for members of my local Model T club, it's actually a lot of fun using the ECCT, then seeing the smiling faces once they install the coils, makes it all worth the exercise.
Regards,
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Sun Feb 17, 2019 11:25 am
Still time to take advantage of this I-Timer discount offer.
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Sat Feb 23, 2019 7:05 am
Only 1 week left.
SurfCityGene
First Name: Gene
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Sat Feb 23, 2019 1:05 pm
KIRK, I hope you have seen this!! I know you've been wanting one for a long time and this is your chance.
KirkieP
First Name: Kirk
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
MTFCA Number: 345
MTFCI Number: 141
Post by KirkieP » Sat Feb 23, 2019 11:29 pm
Gene
We just got back. I'm going to contact Mike Monday.
Kirk Peterson
Santa Fe NM
SurfCityGene
First Name: Gene
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Thu Feb 28, 2019 5:23 pm
Mike, Will you be having another sale on April 1?? This timer would be the ultimate sale item then!!
KirkieP
First Name: Kirk
Last Name: Peterson
MTFCA Number: 345
MTFCI Number: 141
Post by KirkieP » Mon Apr 08, 2019 10:25 am
Just installed and put on 20 miles on I-Timer. Ran flawlessly.
Kirk Peterson
Santa Fe NM
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Wed Jul 31, 2019 9:43 pm
2019 Summer I-Timer Special; offer valid 8/1/2019 through 8/15/2019*
Please include copy of ECCT equipment purchase receipt to qualify for discount. Please add $10 Shipping to lower 48 US states. International buyers, please email for shipping rates. *While supplies last, One discount per customer.
Mictel LLC
244N 17th Street
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Thu Aug 08, 2019 4:33 am
One week remaining, offer expires 8/15/19
Erik Larson - Idaho
First Name: Erik
Last Name: Larson
* REQUIRED* Type and Year of Model Ts owned: 1919 Roadster Pickup, 1923 Touring, 1927 TT, 1914 Touring, 1926 TT C cab, 1924 Fordson F
MTFCA Number: 49553
Post by Erik Larson - Idaho » Mon Aug 12, 2019 1:27 pm
The I-Timer is a high quality product. No maintenance and you can still get free starts! Set it and forget it.
Erik Larson
