Just finished this one up.., designed to be used with an aux transmission with reverse such as a Giant, Jumbo, Muncie, 37-39 Chevy top loader style or any other you wish to have. You still utilize the engine brake and your high low pedal becomes the clutch but totally wet. Has a Kevlar demountable brake band and a new large drum with Jack Rabbit clutches. Also has a machined tail shaft with a ball bearing forth main. The flywheel weighs in at just under 20 Lbs. No large bulking weighted mass moving around so you RPM's really go! if you are planning on a splash system, simply install paddles. Not designed for an internal magneto!
$1,000.00 plus shipping, but prefer pick up.
Email Only to the address provided.
All the Best,
FS High Revving Model T Flywheel/Clutch System SOLD
Topic author - Posts: 5339
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
- First Name: Joseph
- Last Name: Andulics
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 Truck, 1927 Roadster GOW, RAJO Sprint car
- MTFCA Number: 9766
Re: FS High Revving Model T Flywheel/Clutch System
Great idea keeping the transmission brake.
- Last Name: Rehberg
- * REQUIRED* Type and Year of Model Ts owned: 1913 open express
- MTFCA Number: 20693
Hank, I'll match that up with the Chevy transmission you did for me. I'll take it. Unfortunately, I will have to have you ship it.
John Rehberg
John Rehberg
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Sold to John, Thanks MTFCA!
