WTB - Forged L-Shape Front Shackles Set
Topic author - Posts: 112
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
- MTFCA Number: 50735
For ‘22 Centerdoor. Seem to be rare and hard to find, ones that are not badly worn anyway. Anyone out there with a set for the rear as well?
Neither Hank Lee nor Model T Haven have any serviceable ones.
Thanks, Ron
email: rdwenzelATgmailDOTcom
Thanks, Ron
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: WTB - Forged L-Shape Front Shackles Set
Tough item to locate Ron - our '19 uses the same !
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Would any of these work? I have no relation to the seller or the ads.
https://www.ebay.com/itm/Ford-Model-T-S ... SwFYZbv1z2
https://www.ebay.com/itm/Ford-Model-T-S ... SwWudbv10j
https://www.ebay.com/itm/Ford-Model-T-F ... Swvupb0iok
https://www.ebay.com/itm/Ford-Model-T-F ... SwiJhb0ikl
https://www.ebay.com/itm/Ford-Model-T-S ... Swwb1bv13A
https://www.ebay.com/itm/Ford-Model-T-F ... SwhyRb0ipU
- First Name: Ron
- Last Name: Wenzel
Thanks, Mark. I must have missed the magic words when I was searching eBay. Took a close look and best I can tell the ones offered are worn as badly as are mine. May have to bite the bullet and use a repro set until I can find a good set, or, since here in HSV we’re a hotbed of R&D, I might just see what it might take to have some reproduced at a decent price. We’ve got a lot of local precision machine shops.
If I find/make any, Steve, I’ll let you know.
v/r,
Ron
v/r,
Ron
Thanks ! You might check with Bob Bergstadt (Bob's antique Auto Parts) - his Dad had stashes of NOS parts.
He goes by "FATMAN" on the Forum.
- Last Name: Dewey
- MTFCI Number: 19936
A friend of mine takes the ones that aren't worn below the thread diameter, puts them in his lathe (in a fixture) and turns them round, then presses a sleeve on them to bring them back to original diameter--voila! new again.
T'ake care,
David Dewey
David Dewey
- First Name: Ron
- Last Name: Wenzel
Thanks, folks! I’ll have to check with Bob and this also gives me an excuse to get on the move and get the antique lathe out of storage and get it set up. Much appreciated.
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
I have looks to be 3 n.o.s. rears with Ford script and one used rear, Bob
- First Name: Ron
- Last Name: Wenzel
Thanks, Bob, sent you a PM.
- First Name: Ron
- Last Name: Wenzel
And, an email. Thx
Ron
Ron
Ron, they are rebuildable. In past posts Steve Jelf and I showed the tools we used to hold shackles welded up for re turning down to size. Others may be able to refer you to our posts.
- First Name: Ron
- Last Name: Wenzel
Thx, Allan. I’ll see if I can scare up those posts.
Ron
Ron
I just found one pair ( 1 side ) Ford script fronts with good shanks, they are used but still in good shape, see photo's, Bob
- First Name: Ron
- Last Name: Wenzel
Bob, sending you an email. Tnx Ron
- First Name: Ron
- Last Name: Wenzel
Thanks FATMAN and MTFCA! Set of rears are on the way which I also will need.
