Wanted: set of Grant brand .030” rings for aluminum pistons
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Wed Sep 09, 2020 7:10 pm
Email me (don’t pm). Thanks!
Last Name: Hatch
MTFCA Number: 49974
Re: Wanted: set of Grant brand .030” rings for aluminum pistons
Post by Dan Hatch » Thu Sep 10, 2020 1:58 pm
Email sent. Dan
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Fri Sep 11, 2020 10:58 am
I’m no longer in need of the rings. Thanks!
Dan, I just emailed back.
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Sat Sep 12, 2020 1:29 am
I think most aluminum pistons use 1955-1956 chevy 265 cu.in. rings so you can buy them by bore size ie. Std, 10-20-30-over from some suppliers. You do get enough for two engines when you buy a set
George Hand
Last Name: Hand
MTFCA Number: 28114
MTFCI Number: 21834
Post by George Hand » Sat Sep 12, 2020 9:26 am
The top ring groves for an Aluminum Model T Piston are .125", for the 265 ci chevy they are 5/64", oil rings are both 3/16th"
