Wtb 28 chevy adapter plate
Matt_A_1926
First Name: Matt
Last Name: Atchinson
Post by Matt_A_1926 » Sat Sep 12, 2020 12:18 pm
Picked up a 28 chevy head and need an adapter plate. I haven't had any luck contacting Gene so I figured I'd post here in the hopes he or someone else with adapter sees it.
MTFCA Number: 52564
Re: Wtb 28 chevy adapter plate
Post by Mark Gregush » Sat Sep 12, 2020 1:41 pm
Gene is usually pretty quick with replies. He posted in the classifieds in the last week for doing babbitting. Or are you saying you contacted him and he does not have any for sale at this time?
1920 Dodge touring
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Board Member Since: 2014
Post by Gene_French » Sat Sep 12, 2020 2:13 pm
Matt:
i will pass your contact info. onto Scott Hansen ( my neighbor) ... i don't know the current status of finished/un-finished plates or shipment status ... i do know that he has some done , in various stages of completion ... sorry i can not give more details on this project ...always an optimist ...Gene French
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sat Sep 12, 2020 5:46 pm
If required and only if the deal with Gene does not go thru, have a variety of three to choose from. Not hogging Gene in anyway.
Hank (Henry)
Matt_A_1926
First Name: Matt
Post by Matt_A_1926 » Wed Sep 16, 2020 9:08 pm
Thanks guys, and thanks gene. I hope to hear from scott. If not Henry I'll have to inquire with you. What compressions do you have?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Sep 16, 2020 9:10 pm
I have a 7 to 1 and I believe a 6.5 to 1, but give me a few days and I will check.
Hank
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Thu Sep 17, 2020 4:51 pm
Matt:
it has been several years since i calculated the mechanical compression ratio of the adapter plate Scott machined ... seems to have been 5.7:1 as supplied ... this design can be machined on the cylinder head side 3/16" without any need to increase the depth of the socket head screws that are used to mount the head ... if i recall correctly this would raise compression to approx. 7:1 + ... i think this is about all you would want to run with stock crankshaft and rods... this plate worked well at 5.7:1 on an engine i used about 20 years ago ... hope this answers your question ... pictures of this plate are on previous postings ... always an optimist ...Gene French
