Wtb 28 chevy adapter plate
Topic author - Posts: 50
- First Name: Matt
- Last Name: Atchinson
Picked up a 28 chevy head and need an adapter plate. I haven't had any luck contacting Gene so I figured I'd post here in the hopes he or someone else with adapter sees it.
- MTFCA Number: 52564
Re: Wtb 28 chevy adapter plate
Gene is usually pretty quick with replies. He posted in the classifieds in the last week for doing babbitting. Or are you saying you contacted him and he does not have any for sale at this time?
1920 Dodge touring
1920 Dodge touring
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Matt:
i will pass your contact info. onto Scott Hansen ( my neighbor) ... i don't know the current status of finished/un-finished plates or shipment status ... i do know that he has some done , in various stages of completion ... sorry i can not give more details on this project ...always an optimist ...Gene French
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
If required and only if the deal with Gene does not go thru, have a variety of three to choose from. Not hogging Gene in anyway.
Hank (Henry)
Hank (Henry)
- First Name: Matt
Thanks guys, and thanks gene. I hope to hear from scott. If not Henry I'll have to inquire with you. What compressions do you have?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I have a 7 to 1 and I believe a 6.5 to 1, but give me a few days and I will check.
- First Name: Gene
- Last Name: French
Matt:
it has been several years since i calculated the mechanical compression ratio of the adapter plate Scott machined ... seems to have been 5.7:1 as supplied ... this design can be machined on the cylinder head side 3/16" without any need to increase the depth of the socket head screws that are used to mount the head ... if i recall correctly this would raise compression to approx. 7:1 + ... i think this is about all you would want to run with stock crankshaft and rods... this plate worked well at 5.7:1 on an engine i used about 20 years ago ... hope this answers your question ... pictures of this plate are on previous postings ... always an optimist ...Gene French
