Want To Buy: Amethyst H Lenses
Topic author - Posts: 2260
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Looking to make an extra pair (and spares ?) for my truck in a color like shown.
Happy to pay cash. Have clear and lighter pinks to trade, if you are trying to
make matching pairs. Thanks.
- First Name: Brent
- Last Name: Burger
Re: Want To Buy: Amethyst H Lenses
No one has some of these laying around ?
- First Name: Jonah
- Last Name: D'Avella
I have got one, were they original to the car?
- First Name: Brent
- Last Name: Burger
The "H" lens became the standard around 1920 (?) and was used through the
end in 1927. The ones that will turn amethyst seem to show up on the 26-27
vehicles most often. Not sure if that is an accurate suggestion that a late
production run of lenses had manganese in the glass batch, or if it was simply
an intermittent thing. Most "H" lenses are dead clear. Some have enough
manganese in the glass to just turn a pink. Others can get quite dark purple.
- First Name: Jonah
On my 26 touring, I have one clear lens and one amthest.
- First Name: Brent
- Last Name: Burger
That seems to fit the pattern I have seen. Would you like to sell your
amethyst one ? I can send a clear to give you a match. If this is of interest,
take a photo of the lens in question, as I am trying to make a match as
well. Thanks.
well. Thanks.
- First Name: Jonah
Here is a picture.
- First Name: Brent
- Last Name: Burger
Hard to tell the color from that pic. Best to take it loose and lay it on white paper.
- First Name: Jonah
It seems like they are riveted in
- MTFCA Number: 52564
After you take the rim off, you just bend the tabs on a couple of the clips back and lens will come out. Or just flip it over and take from the back side.
1920 Dodge touring
1920 Dodge touring
- First Name: Dennis
- Last Name: Seth
They are not riveted in the light ring pushes in and turns to release the lens and service the bulbs.
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
I have been doing that to one of mine for over a year trying to remove it. Even saturating with Kroil doesn't help.perry kete wrote: ↑Tue Sep 22, 2020 12:30 pmFord Model T Headlight assembly.jpg
- MTFCA Number: 14972
- MTFCI Number: 15411
I've had good luck putting the light on a rubber mat on the floor and using my body weight to push in & twist.
- First Name: Jonah
I will try that
- First Name: Brent
- Last Name: Burger
I was shown a dandy period tool that is in the shape of an "H". The center bar
perfectly holds the legs at a spacing just smaller than the outside dimension of
the ring. Two of the same end of the legs have slots in them, that fit over the
rivets. The non-slotted ends are where the users puts some muscle to the whole
affair to remove stubborn rings. I can post a pic if anyone is interested.
I have found that to remove the headlight rim you must first loosen the rim from the headlight bucket. There is a spring, T-6586X, as shown in the diagram, that often gets stuck to the reflector through rust and/or dirt. So the first step is to break that bond loose by kneading -squeezing the rim against the headlight bucket (palm on the rim and fingers on the bucket). Its necessary to do this around the entire rim until you can fell the rim compress. If the headlight is mounted on the car the you need to rotate the rim counter clockwise while compressing it against the bucket. If the headlight is off the car its easier to have a person hold the headlight bucket while compressing and rotating. It is also possible to place it on a no-skid surface , rim down, and push down and rotate the bucket counter-clockwise. The u-shaped tool only works when the rim is able to be compressed all the way around.
