Rebiult Stromberg OF carburetor
Topic author - Posts: 584
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Rebuilt ,tested, and guaranteed Stromberg OF carb. Intentionally not bead blasted and cleaned on the outside to retain original patina, but totally serviced inside with new gaskets, throttle shaft bushings, fuel sight plug, and new viton tipped needle valve. Both idle and high speed jets adjusted to within one or two notches for your engine. Asking $495 plus shipping from Florida
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Re: Rebiult Stromberg OF carburetor
These are one of the best performing carbs for a T. No adjusting needed just start and drive!
1912 Torpedo Roadster
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
- MTFCA Number: 373
- MTFCI Number: 184
Sent you a pm
- First Name: Bob
- Last Name: Middleton
Bruce sent a PM
- First Name: Bruce
The Stromberg OF is sold to Jim . Thanks to the MTFCA site
