WTB: early water inlet
Topic author - Posts: 333
- First Name: Bill
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
- MTFCA Number: 52438
- MTFCI Number: 22121
I'm looking for an early style water inlet for my 1910 T. They are a bit different than the later T's, and were used from 1909 thru 1913 I believe. The bolt holes had a raised area around them and I think they were a bit straighter in design.
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Re: WTB: early water inlet
Not sure if correct but have repop and a good original one fits a brass radiator 11-15 style
- First Name: Bill
Bob, I may have called it the wrong part name, but I need the one that bolts to the left side of the engine not the one on the front. The early ones (1909-13) had heavy ridges around the bolt mounting holes.
- MTFCA Number: 14972
- MTFCI Number: 15411
No, you didn't - the side one is called a "lower inlet connection" - the head one is the "upper outlet connection".
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
- First Name: Bill
That's it, Kim! Thanks!
