WTS: Spark plug explosion whistle
Topic author - Posts: 8
- Last Name: MacKay
Took this off my car and it’s been sitting on the shelf.
I’m not sure how to post a picture to this ad, but I can email or text a picture if you’re interested. Thanks
*** SOLD ***
*** SOLD ***
- First Name: Jonah
- Last Name: D'Avella
Re: WTS: Spark plug whistle
How does it work?
- Last Name: MacKay
Bump to the top
- Last Name: MacKay
Re: WTS: Spark plug explosion whistle
Feel free to make an offer
- First Name: Jonah
Do you have to remove when the spark plugs to use it?
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
Jonah, You remove the spark plug, Then you screw the whistle with its adapter in place of the spark plug. Then you re-install the spark plug into a hole in the adapter and re-connect the spark plug wire. There will be a small cable or wire attached to the whistle you run thru a hole in the firewall to a place you can reach from the driver seat. By pulling on the cable/wire you can sound the whistle. The whistle only works while the engine is running. They are loud, obnoxious, and just fun .
- First Name: Philip
- Last Name: Lawrence
- MTFCA Number: 5591
- MTFCI Number: 25062
- Board Member Since: 2014
Jonah,
In addition to what Donnie mentioned the explosion whistle makes more of a chirping sound than what you would think of as a whistle blowing sound.
- Last Name: MacKay
Feel free to make an offer.
- Last Name: MacKay
Still available
- First Name: Jonah
Would you send me a picture or two? my email is below
- First Name: Jonah
pm message sent
