This is a pair of 1915 Rear Axle Housings with no reinforcing ribs on the backing plates. I am pretty sure they were only used up to around October 1915.
They have a good layer of old paint and were stored inside for quite a while so there is a good chance they aren’t pitted to bad under the paint. Both housings will need the thrust pins replaced which is no big deal. The holes for the bolts that hold the brake shoes are elongated and there is some wear around the brake cams.
These are a must have part if you are trying to build a correct ‘15.
$50 for the pair plus shipping in the U.S.
For Sale: 1915 Rear Axle Housings - No Ribs
- First Name: anthony
- Last Name: lee
Re: For Sale: 1915 Rear Axle Housings - No Ribs
Hello,
I am interested in the 15 housings, Anthony
Oh. 313 919 1939
Oh. 313 919 1939
Topic author - Posts: 662
- First Name: Ed
- Last Name: Fuller
- MTFCA Number: 29582
- MTFCI Number: 22818
- Board Member Since: 2012
Still for sale.
- First Name: Ed
- Last Name: Fuller
No longer available.
