Front wheel hub Assembly
Topic author - Posts: 21
- First Name: Eric
- MTFCA Number: 49941
WTB. Front hub Assembly for a 1911. I'm sure other years are the same.
- MTFCA Number: 30701
- MTFCI Number: 24033
Re: Front wheel hub Assembly
Not entirely. The earlier years had a much "thinner shoulder" that the hub cab screwed up against. It was changed to a larger one I think maybe 1918? The earlier, thinner hubs were subject to cracking. So if you're desiring correctness...be sure to get a thin one..and good luck. Pretty scarce to find, especially if any decent condition.
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
I had sent you an email asking for a photo or description I wasn't sure want an 11 hub was.
Here is a picture of a 1911 hub found on Ford Fix https://modeltfordfix.com/the-1911-mode ... d-changes/
- Attachments
- hub.jpg (53.36 KiB) Viewed 1014 times
